Group: DynoMotion Message: 10026 From: jackgiz@ymail.com Date: 8/24/2014
Subject: Re: [DynoMotion] Router On/Off [6 Attachments]
Thanks Tom
Sent from my Sprint phone.
----- Reply message -----
From: "Tom Kerekes tk@... [DynoMotion]" <DynoMotion@yahoogroups.com>
Subject: [DynoMotion] Router On/Off [6 Attachments]
Date: Sun, Aug 24, 2014 12:39 PM
Hi Jack,
Step/Dir Outputs (4-7) are available on KFLOP JP5.  You should be able to connect the Gecko to Step/Dir signals there.
Group: DynoMotion Message: 10047 From: jackgiz@ymail.com Date: 8/27/2014
Subject: Re: [DynoMotion] Router On/Off [10 Attachments]
Well that explains why g93 didn't work.  I'll try g92 when I get home.
Subject: [DynoMotion] Router On/Off [10 Attachments]
Date: Wed, Aug 27, 2014 3:06 PM
Hi Jack,
G93 relates to inverse time mode.  Was that a typo?  G92X0Y0Z0 should calculate a G92 offset to make the current position Zero.
G54 should select the first Fixture offset.  By default the first fixture offset is already selected so selecting it again will have no effect.
It is obviously important to set the coordinates origin before running GCode or the code will cut at an arbitrary location.
